Ga door naar hoofdinhoud
Motorola i450 Boost Mobile Headphone Port Replacement
Wat je nodig hebt
    1. Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: stap 1, afbeelding 1 van 3 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: stap 1, afbeelding 2 van 3 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Place the phone on a flat surface with the front facing down.
      • Insert your finger under the gray plastic cover at the bottom end of the phone.
      • Lift the cover off the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola i450 Boost Mobile Headphone Port Replacement, Battery: stap 2, afbeelding 1 van 3 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: stap 2, afbeelding 2 van 3 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: stap 2, afbeelding 3 van 3
      • Place your thumb in the notch in the lower left corner of the battery compartment.
      • Lift the battery up and away from the phone.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: stap 3, afbeelding 1 van 2 Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: stap 3, afbeelding 2 van 2
      • Locate the metal slider that holds the SIM card in place.
      • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola i450 Boost Mobile Headphone Port Replacement: stap 4, afbeelding 1 van 3 Motorola i450 Boost Mobile Headphone Port Replacement: stap 4, afbeelding 2 van 3 Motorola i450 Boost Mobile Headphone Port Replacement: stap 4, afbeelding 3 van 3
      • Lift the metal flap to gain access to the bottom of the SIM card.
      • Remove the SIM card by sliding it out parallel to the bottom of the flap.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola i450 Boost Mobile Headphone Port Replacement, Circuit Board: stap 5, afbeelding 1 van 1
      • Extend the antenna.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola i450 Boost Mobile Headphone Port Replacement: stap 6, afbeelding 1 van 1
      • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
      • If the antenna is not fully extended, the top left screw will not be accessible.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola i450 Boost Mobile Headphone Port Replacement: stap 7, afbeelding 1 van 3 Motorola i450 Boost Mobile Headphone Port Replacement: stap 7, afbeelding 2 van 3 Motorola i450 Boost Mobile Headphone Port Replacement: stap 7, afbeelding 3 van 3
      • Gently lift off the back half of the phone and set to the side.
      • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola i450 Boost Mobile Headphone Port Replacement, Headphone Port: stap 8, afbeelding 1 van 1
      • Locate the headphone port at the bottom right corner of the circuit board.
      • The headphone port cannot be removed from the phone. If cleaning the port does not fix the problem, the entire phone must be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Garrison Stevens
1 Reputatie
6 handleidingen geschreven
Clemson, Team 15-2, Benson Fall 2012 Lid van Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Leden
108 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 724
