Ga door naar hoofdinhoud
Motorola i450 Boost Mobile Circuit Board Replacement
Wat je nodig hebt
  1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: stap 1, afbeelding 1 van 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: stap 1, afbeelding 2 van 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: stap 2, afbeelding 1 van 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: stap 2, afbeelding 2 van 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: stap 2, afbeelding 3 van 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: stap 3, afbeelding 1 van 2 Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: stap 3, afbeelding 2 van 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Circuit Board Replacement: stap 4, afbeelding 1 van 3 Motorola i450 Boost Mobile Circuit Board Replacement: stap 4, afbeelding 2 van 3 Motorola i450 Boost Mobile Circuit Board Replacement: stap 4, afbeelding 3 van 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Circuit Board Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Circuit Board Replacement: stap 7, afbeelding 1 van 3 Motorola i450 Boost Mobile Circuit Board Replacement: stap 7, afbeelding 2 van 3 Motorola i450 Boost Mobile Circuit Board Replacement: stap 7, afbeelding 3 van 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Conclusie
Amber King
8 Reputatie
2 handleidingen geschreven
Clemson, Team 15-2, Benson Fall 2012 Lid van Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 525
