Inleiding
Defective motherboard can cause numerous different problems, and replacing the motherboard is usually a last resort. However, replacement will fix many different problems. This guide has one tricky step, which is removing a ribbon cable, but someone with little to no technical knowledge should be able to follow this guide.
Wat je nodig hebt
Push the tab located at the bottom of the battery towards the top of the phone.
Lift the battery away from the phone.
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
Pull the antenna straight out of the phone.
Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
