Ga door naar hoofdinhoud
Motorola i1000plus Back Cover Replacement
Wat je nodig hebt
  1. Motorola i1000plus Back Cover Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola i1000plus Back Cover Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola i1000plus Back Cover Replacement, Battery: stap 1, afbeelding 3 van 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: stap 2, afbeelding 1 van 3 Motorola i1000plus Back Cover Replacement, Antenna: stap 2, afbeelding 2 van 3 Motorola i1000plus Back Cover Replacement, Antenna: stap 2, afbeelding 3 van 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 3 Motorola i1000plus Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 3 Motorola i1000plus Back Cover Replacement, Back Cover: stap 3, afbeelding 3 van 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: stap 6, afbeelding 1 van 3 Motorola i1000plus Back Cover Replacement: stap 6, afbeelding 2 van 3 Motorola i1000plus Back Cover Replacement: stap 6, afbeelding 3 van 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Conclusie
Austin Lake
501 Reputatie
5 handleidingen geschreven
Clemson, Team 13-3, Benson Fall 2013 Lid van Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 195
