Ga door naar hoofdinhoud
Motorola g stylus battery Replacement
Wat je nodig hebt
  1. Motorola g stylus battery Replacement, remove  the sims card and tray: stap 1, afbeelding 1 van 2 Motorola g stylus battery Replacement, remove  the sims card and tray: stap 1, afbeelding 2 van 2
    • Use your sim card eject tool to remove the sim card and tray.
  2. Motorola g stylus battery Replacement, remove stylus: stap 2, afbeelding 1 van 1
    • Remove your stylus pen from the phone.
  3. Motorola g stylus battery Replacement, removing the back of your phone: stap 3, afbeelding 1 van 3 Motorola g stylus battery Replacement, removing the back of your phone: stap 3, afbeelding 2 van 3 Motorola g stylus battery Replacement, removing the back of your phone: stap 3, afbeelding 3 van 3
    • Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
    • Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
    • As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
  4. Motorola g stylus battery Replacement, top and botttom inside covers: stap 4, afbeelding 1 van 2 Motorola g stylus battery Replacement, top and botttom inside covers: stap 4, afbeelding 2 van 2
    • Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
  5. Motorola g stylus battery Replacement, Removing the battery: stap 5, afbeelding 1 van 1
    • Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
    • New line.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Trent Weaver
232 Reputatie
1 Handleiding geschreven
Één opmerking
Yessir, you the man bro
0% 100% - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 111
Altijd: 7,605
