Ga door naar hoofdinhoud
Motorola Xoom Wifi Earphone Port Replacement
Wat je nodig hebt
  1. Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: stap 1, afbeelding 1 van 2 Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: stap 1, afbeelding 2 van 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Earphone Port Replacement: stap 2, afbeelding 1 van 2 Motorola Xoom Wifi Earphone Port Replacement: stap 2, afbeelding 2 van 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Earphone Port Replacement: stap 3, afbeelding 1 van 3 Motorola Xoom Wifi Earphone Port Replacement: stap 3, afbeelding 2 van 3 Motorola Xoom Wifi Earphone Port Replacement: stap 3, afbeelding 3 van 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: stap 4, afbeelding 1 van 3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: stap 4, afbeelding 2 van 3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: stap 4, afbeelding 3 van 3
    • Remove one screw with a T-5 bit.
    • Lift the black casing off of the ports.
    • Remove earphone port from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Prins
604 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-39, Maness Spring 2014 Lid van Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 285
