Ga door naar hoofdinhoud
Motorola Xoom Wifi Display Assembly Replacement
Wat je nodig hebt
    1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: stap 1, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: stap 1, afbeelding 2 van 2
      • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Xoom Wifi Display Assembly Replacement: stap 2, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement: stap 2, afbeelding 2 van 2
      • Apply light pressure with hand and slide the back plate till it stops in this position.
      • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
      • As soon as the clips are released the back should slide off.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Xoom Wifi Display Assembly Replacement: stap 3, afbeelding 1 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 3, afbeelding 2 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 3, afbeelding 3 van 3
      • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
      • Once both screws are taken out, lift the rest of the backing out of the way.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Xoom Wifi Display Assembly Replacement, Battery: stap 4, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement, Battery: stap 4, afbeelding 2 van 2
      • Remove the two battery leads with a T-5 Torx screwdriver.
      • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Xoom Wifi Display Assembly Replacement: stap 5, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement: stap 5, afbeelding 2 van 2
      • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
      • The battery should lift out easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Xoom Wifi Display Assembly Replacement, Speakers: stap 6, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement, Speakers: stap 6, afbeelding 2 van 2
      • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
      • Replace speaker if necessary.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: stap 7, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: stap 7, afbeelding 2 van 2
      • Use a spudger or a fine tip to lift the black tab to a vertical position.
      • A spudger is needed to remove the plastic border around the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Xoom Wifi Display Assembly Replacement: stap 8, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement: stap 8, afbeelding 2 van 2
      • When lifting the camera out, be sure to pull the orange ribbon cable as well.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: stap 9, afbeelding 1 van 3 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: stap 9, afbeelding 2 van 3 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: stap 9, afbeelding 3 van 3
      • Take a plastic opening tool and carefully pry off the touch screen controller connection.
      • Be careful with the black cover under the connection.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Xoom Wifi Display Assembly Replacement: stap 10, afbeelding 1 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 10, afbeelding 2 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 10, afbeelding 3 van 3
      • There are two relay wires that must be disconnected.
      • Pull both relay wires out of their connection ports.
      • Make sure to flip up the small black tab before you pull out the wire.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Xoom Wifi Display Assembly Replacement: stap 11, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement: stap 11, afbeelding 2 van 2
      • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Xoom Wifi Display Assembly Replacement: stap 12, afbeelding 1 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 12, afbeelding 2 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 12, afbeelding 3 van 3
      • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
      • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
      • Motherboard should lift out easily and completely.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: stap 13, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: stap 13, afbeelding 2 van 2
      • Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Xoom Wifi Display Assembly Replacement: stap 14, afbeelding 1 van 2 Motorola Xoom Wifi Display Assembly Replacement: stap 14, afbeelding 2 van 2
      • Take the small plastic opening tool and separate the front glass from the screen frame.
      • Unfold the glass and the frame flat on the table.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Xoom Wifi Display Assembly Replacement: stap 15, afbeelding 1 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 15, afbeelding 2 van 3 Motorola Xoom Wifi Display Assembly Replacement: stap 15, afbeelding 3 van 3
      • Using the T-5 Torx screwdriver, unscrew the 12 4.1mm screws along the edge of the screen.
      • Pull ribbon wire out of slot in the frame to pull the screen off of the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Andrew Mercier
532 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-39, Maness Spring 2014 Lid van Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 2,040
