Inleiding
As this replacement guide works on an external component of the Xoom Wifi, there are no prerequisite steps.
Wat je nodig hebt
There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
Apply light pressure with hand and slide the back plate till it stops in this position.
There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
As soon as the clips are released the back should slide off.
4 andere personen hebben deze handleiding voltooid.
