Inleiding
Common problems with the screen may include (and are not limited to): dead pixels, images not properly displaying, device isn’t turning on, nothing is showing on the display, etc. When your device isn’t properly displaying images or if there are ‘dead pixels’ in your device, your screen may need to be replaced.
If your Motorola Xoom 2's (MZ615-16) screen is damaged and in need of a replacement this guide can help. Use caution when working on this part because the screen is very fragile.
Wat je nodig hebt
Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
Using a pry tool, gently un-clip the orange ribbon cable attached to the left of the digitizer connector and fold the digitizer connector away from the device.
Één andere persoon heeft deze handleiding voltooid.
