Ga door naar hoofdinhoud
Motorola XOOM 2 Media Edition Battery Replacement
Wat je nodig hebt
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola XOOM 2 Media Edition Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: stap 2, afbeelding 1 van 2 Motorola XOOM 2 Media Edition Battery Replacement: stap 2, afbeelding 2 van 2
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: stap 3, afbeelding 1 van 2 Motorola XOOM 2 Media Edition Battery Replacement: stap 3, afbeelding 2 van 2
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: stap 4, afbeelding 1 van 3 Motorola XOOM 2 Media Edition Battery Replacement: stap 4, afbeelding 2 van 3 Motorola XOOM 2 Media Edition Battery Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: stap 5, afbeelding 1 van 2 Motorola XOOM 2 Media Edition Battery Replacement: stap 5, afbeelding 2 van 2
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
Conclusie
Taylor
197 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,074
