Ga door naar hoofdinhoud
Motorola W490 SIM Card Replacement
Wat je nodig hebt
  1. Motorola W490 SIM Card Replacement, Phone Casing: stap 1, afbeelding 1 van 2 Motorola W490 SIM Card Replacement, Phone Casing: stap 1, afbeelding 2 van 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 SIM Card Replacement, Battery: stap 2, afbeelding 1 van 2 Motorola W490 SIM Card Replacement, Battery: stap 2, afbeelding 2 van 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 3 Motorola W490 SIM Card Replacement, SIM Card: stap 3, afbeelding 2 van 3 Motorola W490 SIM Card Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
Conclusie
Will Edwards
61 Reputatie
9 handleidingen geschreven
Clemson, Team 14-1, Benson Fall 2012 Lid van Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Leden
23 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 802
