Ga door naar hoofdinhoud
Motorola W490 Keypad Replacement
Wat je nodig hebt
  1. Motorola W490 Keypad Replacement, Phone Casing: stap 1, afbeelding 1 van 2 Motorola W490 Keypad Replacement, Phone Casing: stap 1, afbeelding 2 van 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola W490 Keypad Replacement, Battery: stap 2, afbeelding 1 van 2 Motorola W490 Keypad Replacement, Battery: stap 2, afbeelding 2 van 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola W490 Keypad Replacement, SIM Card: stap 3, afbeelding 1 van 3 Motorola W490 Keypad Replacement, SIM Card: stap 3, afbeelding 2 van 3 Motorola W490 Keypad Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola W490 Keypad Replacement, Keypad Membrane: stap 4, afbeelding 1 van 1
    • Open phone so the keypad is facing up.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola W490 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Insert a push pin into the notch located on the left side of the keypad and push the pin under the keypad membrane.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola W490 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Continue working the pin under the keypad membrane until it is elevated enough to grasp.
    Vraag FixBot
    Voeg opmerking toe
  7. Motorola W490 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Grasp the keypad membrane firmly and remove it from the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Motorola W490 Keypad Replacement, Lower Metal Frame: stap 8, afbeelding 1 van 2 Motorola W490 Keypad Replacement, Lower Metal Frame: stap 8, afbeelding 2 van 2
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  9. Motorola W490 Keypad Replacement: stap 9, afbeelding 1 van 3 Motorola W490 Keypad Replacement: stap 9, afbeelding 2 van 3 Motorola W490 Keypad Replacement: stap 9, afbeelding 3 van 3
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
    Vraag FixBot
    Voeg opmerking toe
  10. Motorola W490 Keypad Replacement: stap 10, afbeelding 1 van 2 Motorola W490 Keypad Replacement: stap 10, afbeelding 2 van 2
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
    Vraag FixBot
    Voeg opmerking toe
  11. Motorola W490 Keypad Replacement: stap 11, afbeelding 1 van 3 Motorola W490 Keypad Replacement: stap 11, afbeelding 2 van 3 Motorola W490 Keypad Replacement: stap 11, afbeelding 3 van 3
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
    Vraag FixBot
    Voeg opmerking toe
  12. Motorola W490 Keypad Replacement, Circuit Board: stap 12, afbeelding 1 van 3 Motorola W490 Keypad Replacement, Circuit Board: stap 12, afbeelding 2 van 3 Motorola W490 Keypad Replacement, Circuit Board: stap 12, afbeelding 3 van 3
    • Identify the flex cable attachment. Indicated in a red square.
    • Detach the bottom half of the flex cable, pop it off of the circuit board.
    • Pick up the loosened circuit board from the phone and set aside.
    Vraag FixBot
    Voeg opmerking toe
  13. Motorola W490 Keypad Replacement, Keypad: stap 13, afbeelding 1 van 3 Motorola W490 Keypad Replacement, Keypad: stap 13, afbeelding 2 van 3 Motorola W490 Keypad Replacement, Keypad: stap 13, afbeelding 3 van 3
    • Lay the circuit board down with the keypad facing up.
    • Grab the corner of the keypad and gently peel it away from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Will Edwards
61 Reputatie
9 handleidingen geschreven
Clemson, Team 14-1, Benson Fall 2012 Lid van Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 805
