Ga door naar hoofdinhoud
Motorola W385 speaker replacement
Wat je nodig hebt
  1. Motorola W385 speaker replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 speaker replacement: stap 2, afbeelding 1 van 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 speaker replacement, Front Casing: stap 3, afbeelding 1 van 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 speaker replacement: stap 4, afbeelding 1 van 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 speaker replacement: stap 5, afbeelding 1 van 2 Motorola W385 speaker replacement: stap 5, afbeelding 2 van 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 speaker replacement: stap 6, afbeelding 1 van 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 speaker replacement, Top Logic Board: stap 7, afbeelding 1 van 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 speaker replacement: stap 8, afbeelding 1 van 3 Motorola W385 speaker replacement: stap 8, afbeelding 2 van 3 Motorola W385 speaker replacement: stap 8, afbeelding 3 van 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 speaker replacement: stap 9, afbeelding 1 van 3 Motorola W385 speaker replacement: stap 9, afbeelding 2 van 3 Motorola W385 speaker replacement: stap 9, afbeelding 3 van 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 speaker replacement, Main Speaker: stap 10, afbeelding 1 van 1
    • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
  11. Motorola W385 speaker replacement: stap 11, afbeelding 1 van 2 Motorola W385 speaker replacement: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Place the spudger between the speaker and the clip shown.
    • Separate the clip from the speaker while lifting on the speaker.
    • The speaker should separate. Use the tweezers to grab the speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Koedy Brant
41 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-50, Regan Winter 2010 Lid van Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 3,259
