Inleiding
Is the plastic casing cracked or severely scratched? Replace it.
Wat je nodig hebt
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
Één andere persoon heeft deze handleiding voltooid.
