Ga door naar hoofdinhoud
Motorola W315 Rear Case Replacement
Wat je nodig hebt
  1. Motorola W315 Rear Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Insert the new battery.
  3. Motorola W315 Rear Case Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Rear Case Replacement: stap 5, afbeelding 1 van 3 Motorola W315 Rear Case Replacement: stap 5, afbeelding 2 van 3 Motorola W315 Rear Case Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
Conclusie
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
501 Reputatie
5 handleidingen geschreven
Clemson, Team 6-3, Benson Spring 2014 Lid van Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 224
