Ga door naar hoofdinhoud
Motorola W315 Antenna Replacement
Wat je nodig hebt
  1. Motorola W315 Antenna Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Antenna Replacement: stap 3, afbeelding 1 van 1
    • Insert the new battery.
  3. Motorola W315 Antenna Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Antenna Replacement: stap 5, afbeelding 1 van 3 Motorola W315 Antenna Replacement: stap 5, afbeelding 2 van 3 Motorola W315 Antenna Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Antenna Replacement, Antenna: stap 6, afbeelding 1 van 1
    • Gently twist the antenna in a counter-clockwise direction to unscrew it.
  6. Motorola W315 Antenna Replacement: stap 7, afbeelding 1 van 2 Motorola W315 Antenna Replacement: stap 7, afbeelding 2 van 2
    • Pull the antenna out through the hole in the top of the frame and set it aside.
  7. Motorola W315 Antenna Replacement: stap 8, afbeelding 1 van 3 Motorola W315 Antenna Replacement: stap 8, afbeelding 2 van 3 Motorola W315 Antenna Replacement: stap 8, afbeelding 3 van 3
    • Using a plastic opening tool, lift and remove the antenna casing.
Conclusie
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
501 Reputatie
5 handleidingen geschreven
Clemson, Team 6-3, Benson Spring 2014 Lid van Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 196
