Ga door naar hoofdinhoud
Motorola V710 Camera Replacement
Wat je nodig hebt
  1. Motorola V710 Camera Replacement, Screen: stap 1, afbeelding 1 van 3 Motorola V710 Camera Replacement, Screen: stap 1, afbeelding 2 van 3 Motorola V710 Camera Replacement, Screen: stap 1, afbeelding 3 van 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 Camera Replacement: stap 2, afbeelding 1 van 2 Motorola V710 Camera Replacement: stap 2, afbeelding 2 van 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 Camera Replacement: stap 3, afbeelding 1 van 2 Motorola V710 Camera Replacement: stap 3, afbeelding 2 van 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 Camera Replacement: stap 4, afbeelding 1 van 2 Motorola V710 Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 Camera Replacement: stap 5, afbeelding 1 van 2 Motorola V710 Camera Replacement: stap 5, afbeelding 2 van 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 Camera Replacement: stap 6, afbeelding 1 van 2 Motorola V710 Camera Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger to remove the screen.
  7. Motorola V710 Camera Replacement, Camera: stap 7, afbeelding 1 van 3 Motorola V710 Camera Replacement, Camera: stap 7, afbeelding 2 van 3 Motorola V710 Camera Replacement, Camera: stap 7, afbeelding 3 van 3
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
Conclusie
Karl Sanders
8 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-49, Regan Winter 2010 Lid van Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 76
Altijd: 1,842
