Ga door naar hoofdinhoud
Motorola V60s Speakers Replacement
Wat je nodig hebt
  1. Motorola V60s Speakers Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola V60s Speakers Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola V60s Speakers Replacement, Battery: stap 1, afbeelding 3 van 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: stap 2, afbeelding 1 van 2 Motorola V60s Speakers Replacement: stap 2, afbeelding 2 van 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: stap 3, afbeelding 1 van 2 Motorola V60s Speakers Replacement, Speakers: stap 3, afbeelding 2 van 2
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: stap 4, afbeelding 1 van 2 Motorola V60s Speakers Replacement: stap 4, afbeelding 2 van 2
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: stap 5, afbeelding 1 van 1
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Conclusie
Eric Freeman
10 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-48, Regan Winter 2010 Lid van Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,572
