Ga door naar hoofdinhoud
Motorola V60s Button Key Pad Replacement
Wat je nodig hebt
  1. Motorola V60s Button Key Pad Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola V60s Button Key Pad Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola V60s Button Key Pad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Pad Replacement: stap 2, afbeelding 1 van 2 Motorola V60s Button Key Pad Replacement: stap 2, afbeelding 2 van 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Pad Replacement, Logic Board: stap 3, afbeelding 1 van 2 Motorola V60s Button Key Pad Replacement, Logic Board: stap 3, afbeelding 2 van 2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Pad Replacement: stap 4, afbeelding 1 van 3 Motorola V60s Button Key Pad Replacement: stap 4, afbeelding 2 van 3 Motorola V60s Button Key Pad Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Pad Replacement: stap 5, afbeelding 1 van 3 Motorola V60s Button Key Pad Replacement: stap 5, afbeelding 2 van 3 Motorola V60s Button Key Pad Replacement: stap 5, afbeelding 3 van 3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Pad Replacement: stap 6, afbeelding 1 van 3 Motorola V60s Button Key Pad Replacement: stap 6, afbeelding 2 van 3 Motorola V60s Button Key Pad Replacement: stap 6, afbeelding 3 van 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Pad Replacement: stap 7, afbeelding 1 van 2 Motorola V60s Button Key Pad Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: stap 8, afbeelding 1 van 2 Motorola V60s Button Key Pad Replacement, Button Key Board: stap 8, afbeelding 2 van 2
    • Insert spudger under button board and gently lift, set aside.
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: stap 9, afbeelding 1 van 2 Motorola V60s Button Key Pad Replacement, Button Key Pad: stap 9, afbeelding 2 van 2
    • Life button keypad with spudger and set aside.
Conclusie
Eric Freeman
10 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-48, Regan Winter 2010 Lid van Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,032
