Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the phone over so the back cover is facing up.
Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
Pry up the back plate from the phone.
Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
Simultaneously press the highlighted buttons on both sides of phone.
Place logic board on front cover.
Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Once logic board is removed lift the green keypad sensor for the front plate.
