Ga door naar hoofdinhoud
Motorola V60i Keypad Sensor Replacement
Wat je nodig hebt
  1. Motorola V60i Keypad Sensor Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola V60i Keypad Sensor Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Keypad Sensor Replacement: stap 2, afbeelding 1 van 2 Motorola V60i Keypad Sensor Replacement: stap 2, afbeelding 2 van 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Keypad Sensor Replacement, Back Plate: stap 3, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Keypad Sensor Replacement: stap 4, afbeelding 1 van 2 Motorola V60i Keypad Sensor Replacement: stap 4, afbeelding 2 van 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Keypad Sensor Replacement: stap 5, afbeelding 1 van 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Motorola V60i Keypad Sensor Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Gently lift logic board from back plate.
  7. Motorola V60i Keypad Sensor Replacement: stap 7, afbeelding 1 van 2 Motorola V60i Keypad Sensor Replacement: stap 7, afbeelding 2 van 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  8. Motorola V60i Keypad Sensor Replacement, Keypad Sensor: stap 8, afbeelding 1 van 2 Motorola V60i Keypad Sensor Replacement, Keypad Sensor: stap 8, afbeelding 2 van 2
    • Once logic board is removed lift the green keypad sensor for the front plate.
Conclusie
Elizabeth OBrien
43 Reputatie
7 handleidingen geschreven
Cal Poly, Team 30-40, Garner Spring 2010 Lid van Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Leden
14 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,994
