Ga door naar hoofdinhoud
Motorola V60c Keypad and Keypad Logic Board Replacement
Wat je nodig hebt
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 2, afbeelding 1 van 2 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 2, afbeelding 2 van 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: stap 3, afbeelding 1 van 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 4, afbeelding 1 van 2 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 4, afbeelding 2 van 2
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 6, afbeelding 1 van 2 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 7, afbeelding 1 van 2 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 7, afbeelding 2 van 2
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: stap 8, afbeelding 1 van 3 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 8, afbeelding 2 van 3 Motorola V60c Keypad and Keypad Logic Board Replacement: stap 8, afbeelding 3 van 3
    • Remove the keypad.
Conclusie
Ryan Kuroiwa
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-86, Amido Spring 2010 Lid van Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 2,302
