Inleiding
This guide is useful when encountering broken or stuck keys.
Onderdelen
Geen onderdelen opgegeven.
Push down on the silver button while sliding the back plate down to reveal the battery.
Move the the metal slider towards the top of the phone until it clicks out of its original position.
Slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Remove the screw covers over the two top screws by prying gently with a pin.
The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
Separate the front ribbon cable from the board with a plastic opening tool.
With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
Één andere persoon heeft deze handleiding voltooid.
