Inleiding
This guide shows how to remove the front inside speaker of a Motorola V557 phone.
Wat je nodig hebt
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
Gently peel off the plastic film from the metal plate above the camera lens as shown.
Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
Pry the speaker out of the case by wedging a pin under the wire mesh.
