Ga door naar hoofdinhoud
Motorola V557 External Speaker Replacement
Wat je nodig hebt
    1. Motorola V557 External Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola V557 External Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola V557 External Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
      • First, on the back of the phone find the silver button on the top left corner of the phone.
      • Simultaneously push down the button and slide the back plate down to reveal the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola V557 External Speaker Replacement: stap 2, afbeelding 1 van 2 Motorola V557 External Speaker Replacement: stap 2, afbeelding 2 van 2
      • Grab the lower edge of the battery at the two bottom corners.
      • Pull upward on the edges to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola V557 External Speaker Replacement, SIM Card: stap 3, afbeelding 1 van 3 Motorola V557 External Speaker Replacement, SIM Card: stap 3, afbeelding 2 van 3 Motorola V557 External Speaker Replacement, SIM Card: stap 3, afbeelding 3 van 3
      • Push the metal slider towards the top of the phone until it clicks out of the original position.
      • Gently slide out and remove the SIM card.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola V557 External Speaker Replacement, Antenna: stap 4, afbeelding 1 van 2 Motorola V557 External Speaker Replacement, Antenna: stap 4, afbeelding 2 van 2
      • Grip the antenna and twist it counterclockwise to loosen it.
      • When it has been loosened all the way, pull gently to remove the antenna piece.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola V557 External Speaker Replacement, Rear Casing: stap 5, afbeelding 1 van 3 Motorola V557 External Speaker Replacement, Rear Casing: stap 5, afbeelding 2 van 3 Motorola V557 External Speaker Replacement, Rear Casing: stap 5, afbeelding 3 van 3
      • Using the push pin, gently pry the top two screws of the cover off.
      • The cover in the upper left of the back plate does not need to be removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola V557 External Speaker Replacement: stap 6, afbeelding 1 van 3 Motorola V557 External Speaker Replacement: stap 6, afbeelding 2 van 3 Motorola V557 External Speaker Replacement: stap 6, afbeelding 3 van 3
      • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola V557 External Speaker Replacement: stap 7, afbeelding 1 van 3 Motorola V557 External Speaker Replacement: stap 7, afbeelding 2 van 3 Motorola V557 External Speaker Replacement: stap 7, afbeelding 3 van 3
      • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
      • Then, separate and detach the rear casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola V557 External Speaker Replacement, Headphone Jack: stap 8, afbeelding 1 van 3 Motorola V557 External Speaker Replacement, Headphone Jack: stap 8, afbeelding 2 van 3 Motorola V557 External Speaker Replacement, Headphone Jack: stap 8, afbeelding 3 van 3
      • Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
      • Insert the new headphone jack assembly and repeat these steps in reverse order.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola V557 External Speaker Replacement, External Speaker: stap 9, afbeelding 1 van 2 Motorola V557 External Speaker Replacement, External Speaker: stap 9, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using metal tweezers, lift out the black plastic support piece from beneath the headphone jack.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola V557 External Speaker Replacement: stap 10, afbeelding 1 van 3 Motorola V557 External Speaker Replacement: stap 10, afbeelding 2 van 3 Motorola V557 External Speaker Replacement: stap 10, afbeelding 3 van 3
      • Separate the speaker from the casing by pushing with a pin from the back (external) side, through the openings in the casing.
      • Be gentle! The wire mesh is durable, but it might suffer damage if you push too hard with the pin.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alex Georges
40 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-50, Amido Fall 2010 Lid van Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Leden
144 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 1,333
