Ga door naar hoofdinhoud
Motorola V551 Keypad Replacement
Wat je nodig hebt
  1. Motorola V551 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola V551 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Replacement, Circuit Board: stap 3, afbeelding 1 van 3 Motorola V551 Keypad Replacement, Circuit Board: stap 3, afbeelding 2 van 3 Motorola V551 Keypad Replacement, Circuit Board: stap 3, afbeelding 3 van 3
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the antenna.
  5. Motorola V551 Keypad Replacement: stap 5, afbeelding 1 van 3 Motorola V551 Keypad Replacement: stap 5, afbeelding 2 van 3 Motorola V551 Keypad Replacement: stap 5, afbeelding 3 van 3
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Replacement: stap 6, afbeelding 1 van 2 Motorola V551 Keypad Replacement: stap 6, afbeelding 2 van 2
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Replacement: stap 7, afbeelding 1 van 3 Motorola V551 Keypad Replacement: stap 7, afbeelding 2 van 3 Motorola V551 Keypad Replacement: stap 7, afbeelding 3 van 3
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Replacement, Keypad: stap 8, afbeelding 1 van 3 Motorola V551 Keypad Replacement, Keypad: stap 8, afbeelding 2 van 3 Motorola V551 Keypad Replacement, Keypad: stap 8, afbeelding 3 van 3
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
Conclusie
gregatron
105 Reputatie
6 handleidingen geschreven
Cal Poly, Team 6-6, Maness Fall 2009 Lid van Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,084
