Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Replacing the phone's headphone jack.
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the silver button on the back of the phone, near the bottom.
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Note the metal connections on the phone, which are now exposed with the battery removed. There are corresponding metal connectors on the replacement battery.
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  5. Use Spudger to remove rubber plug from upper left corner of the back of the phone
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  6. Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  7. Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate. Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  8. On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Conclusie
Jason Kilroy
1 Reputatie
3 handleidingen geschreven
Cal Poly, Team 27-96, Amido Spring 2010 Lid van Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Leden
15 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 818
