Inleiding
Replacing the phone's headphone jack.
Onderdelen
Geen onderdelen nodig.
  1. Locate the silver button on the back of the phone, near the bottom.
    • Locate the silver button on the back of the phone, near the bottom.
    • Press down the button with one hand whilst sliding the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • With a firm grip, gently lift the end of your tool up. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Conclusie
Jason Kilroy
1 Reputatie
3 handleidingen geschreven
Cal Poly, Team 27-96, Amido Spring 2010 Lid van Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Leden
15 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 814
