Ga door naar hoofdinhoud
Motorola V180 Connector Ribbon Replacement
Wat je nodig hebt
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: stap 1, afbeelding 1 van 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: stap 3, afbeelding 1 van 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: stap 4, afbeelding 1 van 1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: stap 5, afbeelding 1 van 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: stap 6, afbeelding 1 van 1
    • Use a soldering iron to detach the connector ribbon from the phone.
Conclusie
Tyler Knisley
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 6-16, Maness Spring 2010 Lid van Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 9
Altijd: 2,621
