Ga door naar hoofdinhoud
Motorola SURFboard SB5101 Motherboard Replacement
Wat je nodig hebt
  1. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: stap 1, afbeelding 1 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: stap 1, afbeelding 2 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: stap 1, afbeelding 3 van 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: stap 2, afbeelding 1 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: stap 2, afbeelding 2 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: stap 2, afbeelding 3 van 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: stap 3, afbeelding 1 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: stap 3, afbeelding 2 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: stap 3, afbeelding 3 van 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Motherboard Replacement, Grabbing the Motherboard: stap 4, afbeelding 1 van 2 Motorola SURFboard SB5101 Motherboard Replacement, Grabbing the Motherboard: stap 4, afbeelding 2 van 2
    • After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
  5. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: stap 5, afbeelding 1 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: stap 5, afbeelding 2 van 3 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: stap 5, afbeelding 3 van 3
    • Slowly lift the motherboard out of the case.
Conclusie
To replace the motherboard, follow these instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
Cayce Rast
421 Reputatie
3 handleidingen geschreven
Clemson, Team 1-2, Benson Fall 2014 Lid van Clemson, Team 1-2, Benson Fall 2014
CLEM-BENSON-F14S1G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 6,647
