Ga door naar hoofdinhoud
Motorola Razr V3m Screen/Camera Replacement
Wat je nodig hebt
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Razr V3m Screen/Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: stap 2, afbeelding 1 van 2 Motorola Razr V3m Screen/Camera Replacement: stap 2, afbeelding 2 van 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: stap 3, afbeelding 1 van 2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: stap 3, afbeelding 2 van 2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: stap 6, afbeelding 1 van 1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: stap 7, afbeelding 1 van 2 Motorola Razr V3m Screen/Camera Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Simcock
731 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Lid van UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Leden
7 handleidingen geschreven
Één opmerking
where can this part be purchased?
Alex Alexander - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 416
