Ga door naar hoofdinhoud
Motorola Razr V3c Speaker (CDMA) Replacement
Wat je nodig hebt
  1. Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 1 van 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 2 van 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 3 van 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Speaker (CDMA) Replacement: stap 2, afbeelding 1 van 2 Motorola Razr V3c Speaker (CDMA) Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Speaker (CDMA) Replacement, Speaker (CDMA): stap 3, afbeelding 1 van 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Speaker (CDMA) Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Speaker (CDMA) Replacement: stap 5, afbeelding 1 van 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Speaker (CDMA) Replacement: stap 6, afbeelding 1 van 2 Motorola Razr V3c Speaker (CDMA) Replacement: stap 6, afbeelding 2 van 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Speaker (CDMA) Replacement: stap 7, afbeelding 1 van 2 Motorola Razr V3c Speaker (CDMA) Replacement: stap 7, afbeelding 2 van 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Speaker (CDMA) Replacement: stap 8, afbeelding 1 van 1
    • Pull out the speaker.
Conclusie
Joshua Ruehlig
506 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-4, Forte Winter 2010 Lid van Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 5,424
