Inleiding
This guide will show you how to remove and replace the screen for a Motorola V3c.
Onderdelen
Geen onderdelen nodig.
  1. Remove the four rubber pieces from all corners of the area that borders the screen.
    • Remove the four rubber pieces from all corners of the area that borders the screen.
    Voeg opmerking toe
  2. Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
    Voeg opmerking toe
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
    Voeg opmerking toe
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
    Voeg opmerking toe
  3. Verspreid de kerstsfeer
    Krijg 12€ korting op je aankoop van 50€ of meer met de code FIXMAS12
    • Pry screen cover off with plastic spudger.
    • The screen cover has some adhesive holding it to the screen
    Voeg opmerking toe
    • Remove small black sticker covering the camera ribbon connector.
    Voeg opmerking toe
    • Flip over small hinge that covers the camera ribbon connection.
    Voeg opmerking toe
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
    Voeg opmerking toe
    • Disconnect the metallic ribbon cover.
    Voeg opmerking toe
    • Remove and replace the screen.
    Voeg opmerking toe
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Joshua Ruehlig
503 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-4, Forte Winter 2010 Lid van Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Leden
8 handleidingen geschreven
Één commentaar
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 14
Altijd: 8,968
