Ga door naar hoofdinhoud
Motorola Razr V3c Lower Casing (CDMA) Replacement
Wat je nodig hebt
    1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 1 van 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 2 van 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): stap 1, afbeelding 3 van 3
      • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
      • Lift and remove the rear panel away from the V3c.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 2, afbeelding 1 van 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 2, afbeelding 2 van 2
      • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): stap 3, afbeelding 1 van 1
      • Unscrew the two screws in the back using the T6.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 4, afbeelding 1 van 1
      • Use the plastic opening tool to pop the bottom and the sides off the back casing.
      • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 5, afbeelding 1 van 1
      • Peel off the connector between the motherboard and the body of the phone.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 6, afbeelding 1 van 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Pull out the two black rubber covers using tweezers.
      • The second rubber cover is much harder to get out.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 7, afbeelding 1 van 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 7, afbeelding 2 van 2
      • Pull out the white plastic cover by unclipping the two plastic pieces shown.
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 8, afbeelding 1 van 1
      • Pull out the speaker.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): stap 9, afbeelding 1 van 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): stap 9, afbeelding 2 van 2
      • Pull out the motherboard.
      • You may also now replace the bottom lower casing
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): stap 10, afbeelding 1 van 1
      • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Razr V3c Lower Casing (CDMA) Replacement: stap 11, afbeelding 1 van 1
      • Pull off and replace the lower front casing
      • The metallic grounding grid will come off when the lower front casing is removed
      • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
krisko
104 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-4, Forte Winter 2010 Lid van Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Leden
96 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 40
Altijd: 6,708
