Ga door naar hoofdinhoud
Motorola Razr V3c Camera (CDMA) Replacement
Wat je nodig hebt
  1. Motorola Razr V3c Camera (CDMA) Replacement, Upper Casing (CDMA): stap 1, afbeelding 1 van 1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Camera (CDMA) Replacement: stap 2, afbeelding 1 van 1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Camera (CDMA) Replacement: stap 3, afbeelding 1 van 1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Camera (CDMA) Replacement: stap 4, afbeelding 1 van 3 Motorola Razr V3c Camera (CDMA) Replacement: stap 4, afbeelding 2 van 3 Motorola Razr V3c Camera (CDMA) Replacement: stap 4, afbeelding 3 van 3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  5. Motorola Razr V3c Camera (CDMA) Replacement, Camera (CDMA): stap 5, afbeelding 1 van 2 Motorola Razr V3c Camera (CDMA) Replacement, Camera (CDMA): stap 5, afbeelding 2 van 2
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
  6. Motorola Razr V3c Camera (CDMA) Replacement: stap 6, afbeelding 1 van 1
    • Remove small black sticker covering the camera ribbon connector.
  7. Motorola Razr V3c Camera (CDMA) Replacement: stap 7, afbeelding 1 van 1
    • Flip over small hinge that covers the camera ribbon connection.
  8. Motorola Razr V3c Camera (CDMA) Replacement: stap 8, afbeelding 1 van 3 Motorola Razr V3c Camera (CDMA) Replacement: stap 8, afbeelding 2 van 3 Motorola Razr V3c Camera (CDMA) Replacement: stap 8, afbeelding 3 van 3
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
Eindstreep
Joshua Ruehlig
506 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-4, Forte Winter 2010 Lid van Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 14
Altijd: 4,595
