Ga door naar hoofdinhoud
Motorola Razr V3 Upper Casing Replacement
Wat je nodig hebt
  1. Motorola Razr V3 Upper Casing Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Razr V3 Upper Casing Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Upper Casing Replacement: stap 2, afbeelding 1 van 2 Motorola Razr V3 Upper Casing Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Upper Casing Replacement, Upper Casing: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 Upper Casing Replacement: stap 4, afbeelding 1 van 1
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 Upper Casing Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
Conclusie
Ian Cottengim
172 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-46, Amido Spring 2013 Lid van Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 3,235
