Ga door naar hoofdinhoud
Motorola Razr V3 LCD Screens and Call Speaker Replacement
Wat je nodig hebt
  1. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 2, afbeelding 1 van 2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Upper Casing: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
  6. Motorola Razr V3 LCD Screens and Call Speaker Replacement, LCD Screens and Call Speaker: stap 6, afbeelding 1 van 1
    • Use the spudger to pry off the plastic lens that covers the LCD screen.
    • You will feel some resistance due to the adhesive put in between the screen and the plastic lens. Be careful not to damage the LCD screen.
    • When reassembling, put the screen lens on last. It is much easier to align the lens when you use the upper casing as a guide.
  7. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 7, afbeelding 1 van 1
    • Use the tweezers to gently pry the silver ribbon cable up towards you.
    • Be careful not to damage the ribbon cable when pulling it off, as it can be fragile.
  8. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 8, afbeelding 1 van 2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 8, afbeelding 2 van 2
    • Use he tweezers to flip up the tab.
    • With the tab up, gently pull the copper ribbon cable out.
    • Be careful not to damage the ribbon cable when pulling it out, as it is fragile.
  9. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 9, afbeelding 1 van 2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 9, afbeelding 2 van 2
    • Use the tweezers to gently fold the buttons away from the phone.
    • Be careful not to rip buttons off of the board. You will feel some resistance from the adhesive, but they should easily fold up if they are pulled from the bottom.
    • Use the spudger the speaker from the phone.
  10. Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 10, afbeelding 1 van 2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: stap 10, afbeelding 2 van 2
    • Place your thumb on the screen and gently push into the phone.
    • It should come out pretty easy. If it is not budging go back and check over the steps again.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Christian
269 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-46, Amido Spring 2013 Lid van Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 57
Altijd: 10,716
