Inleiding
This guide will show you how to install the Motorola Razr V3 camera. You may need to install a new camera if the camera doesn't show any picture or otherwise does not work.
Wat je nodig hebt
Video overzicht
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to pry off the four rubber screw covers from the inside face.
Use tweezers to flip up the ZIF tab on the camera ribbon cable socket.
Gently pull the camera ribbon cable out of the ZIF socket.
