Ga door naar hoofdinhoud
Motorola RIZR Z3 Motherboard Replacement
Wat je nodig hebt
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Motherboard Replacement: stap 2, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Motherboard Replacement: stap 4, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Motherboard Replacement: stap 6, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Motherboard Replacement: stap 7, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Motherboard Replacement: stap 8, afbeelding 1 van 2 Motorola RIZR Z3 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
Conclusie
Andrew Brock
8 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-34, Amido Fall 2011 Lid van Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,342
