Ga door naar hoofdinhoud
Inleiding
Motorola RFS4000 Wireless Switch is an integrated controller service designed to provide comprehensive, secure, high-performance and cost-effective integrated wired and wireless network services.
The RFS4000 provides complete voice services, multiple location technologies, and support for multiple RF technologies.
  1. Motorola RFS4000 Disassembly, Removing the screw: stap 1, afbeelding 1 van 3 Motorola RFS4000 Disassembly, Removing the screw: stap 1, afbeelding 2 van 3 Motorola RFS4000 Disassembly, Removing the screw: stap 1, afbeelding 3 van 3
    • Screw
    • Torx T8
    • If you don't have a Torx T8 screwdriver you can use a slotted screwdriver
  2. Motorola RFS4000 Disassembly, Opening the chassis: stap 2, afbeelding 1 van 2 Motorola RFS4000 Disassembly, Opening the chassis: stap 2, afbeelding 2 van 2
    • Slide up the cover
    • Fan cable
    • Before unscrew you must disconnect the fan cable.
  3. Motorola RFS4000 Disassembly, Removing the fan: stap 3, afbeelding 1 van 3 Motorola RFS4000 Disassembly, Removing the fan: stap 3, afbeelding 2 van 3 Motorola RFS4000 Disassembly, Removing the fan: stap 3, afbeelding 3 van 3
    • Fan chassis screws
    • Fan screws
    • Reset Button
    • Power Inlet
  4. Motorola RFS4000 Disassembly, Removing the motherboard: stap 4, afbeelding 1 van 3 Motorola RFS4000 Disassembly, Removing the motherboard: stap 4, afbeelding 2 van 3 Motorola RFS4000 Disassembly, Removing the motherboard: stap 4, afbeelding 3 van 3
    • Motherboard screws
    • RJ45 ports
    • Console port (rj45) and usb port
    • Express card
    • SFP port (Motorola part number: Fiber-3000-1S-WWR)
    • Reset button
Conclusie
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Één andere persoon heeft deze handleiding voltooid.
Eneider Colina
2.332 Reputatie
9 handleidingen geschreven
Één commentaar
No, it's better not to use a slotted screwdriver, because the screws are tightened quite tight (if they haven't already been unscrewed) and you destroy the screws with them. Time required 30 minutes :-))? 10-15 maybe
omanoman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 169
