Inleiding
Use this guide to remove and install a keypad in a Motorola RAZR2 v9m. Also works for other RAZR2 v8 and RAZR v9 models.
Wat je nodig hebt
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Flip the RAZR2 open with the battery compartment facing you.
Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
