Ga door naar hoofdinhoud
Motorola RAZR V3i Battery Replacement
Wat je nodig hebt
  1. Motorola RAZR V3i Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: stap 2, afbeelding 1 van 3 Motorola RAZR V3i Battery Replacement: stap 2, afbeelding 2 van 3 Motorola RAZR V3i Battery Replacement: stap 2, afbeelding 3 van 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: stap 3, afbeelding 1 van 3 Motorola RAZR V3i Battery Replacement: stap 3, afbeelding 2 van 3 Motorola RAZR V3i Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Nigel
133 Reputatie
2 handleidingen geschreven
Cuesta, Team 1-5, Zipperian Fall 2011 Lid van Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Lid
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 55
Altijd: 7,358
