Ga door naar hoofdinhoud
Motorola RAZR Maxx HD Front-Facing Camera Replacement
Wat je nodig hebt
  1. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: stap 1, afbeelding 1 van 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: stap 1, afbeelding 2 van 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 2, afbeelding 1 van 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 3, afbeelding 1 van 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 4, afbeelding 1 van 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 1 van 1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 6, afbeelding 1 van 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 6, afbeelding 2 van 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 7, afbeelding 1 van 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Syage
284 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-40, Amido Winter 2015 Lid van Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 311
