Ga door naar hoofdinhoud
Motorola RAZR Maxx HD External Speaker Replacement
Wat je nodig hebt
  1. Motorola RAZR Maxx HD External Speaker Replacement, Screen Removal: stap 1, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement, Screen Removal: stap 1, afbeelding 2 van 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD External Speaker Replacement: stap 2, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 2, afbeelding 2 van 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD External Speaker Replacement: stap 3, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 3, afbeelding 2 van 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD External Speaker Replacement: stap 4, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 4, afbeelding 2 van 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: stap 5, afbeelding 1 van 3 Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: stap 5, afbeelding 2 van 3 Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: stap 5, afbeelding 3 van 3
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
  6. Motorola RAZR Maxx HD External Speaker Replacement: stap 6, afbeelding 1 van 1
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
  7. Motorola RAZR Maxx HD External Speaker Replacement: stap 7, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
  8. Motorola RAZR Maxx HD External Speaker Replacement: stap 8, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 8, afbeelding 2 van 2
    • Using tweezers, remove the back facing camera cover.
  9. Motorola RAZR Maxx HD External Speaker Replacement: stap 9, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement: stap 9, afbeelding 2 van 2
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  10. Motorola RAZR Maxx HD External Speaker Replacement: stap 10, afbeelding 1 van 1
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
  11. Motorola RAZR Maxx HD External Speaker Replacement: stap 11, afbeelding 1 van 3 Motorola RAZR Maxx HD External Speaker Replacement: stap 11, afbeelding 2 van 3 Motorola RAZR Maxx HD External Speaker Replacement: stap 11, afbeelding 3 van 3
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
  12. Motorola RAZR Maxx HD External Speaker Replacement, External Speaker: stap 12, afbeelding 1 van 2 Motorola RAZR Maxx HD External Speaker Replacement, External Speaker: stap 12, afbeelding 2 van 2
    Koop
    • Use tweezers to remove the speaker from the top left of the phone by pulling upward.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Anna Sullivan
880 Reputatie
3 handleidingen geschreven
Cal Poly, Team 8-40, Amido Winter 2015 Lid van Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 465
