Ga door naar hoofdinhoud
Motorola Q Global Speakers Replacement
Wat je nodig hebt
  1. Motorola Q Global Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: stap 2, afbeelding 1 van 2 Motorola Q Global Speakers Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: stap 3, afbeelding 1 van 1
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: stap 4, afbeelding 1 van 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: stap 5, afbeelding 1 van 2 Motorola Q Global Speakers Replacement: stap 5, afbeelding 2 van 2
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: stap 6, afbeelding 1 van 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: stap 7, afbeelding 1 van 1
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: stap 8, afbeelding 1 van 1
    • Insert the new speakers by gently pressing them down into place.
Conclusie
Carlos De La Parra
14 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-31, Regan Fall 2012 Lid van Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 646
