Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
Slide the upper case to the right and lift up.
Lift the camera sticker so that it doesn't get damaged.
Remove the six labeled screws with a T5 Torx Screwdriver.
Once the screws are removed, use the plastic opening tool to remove the black casing.
Remove both screws on the mounted surface with a T5 screwdriver.
Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
Use the plastic opening tool to lift the camera from the phone.
The new camera can now be attached to the motherboard.
