Ga door naar hoofdinhoud
Motorola Photon 4G MB855 Headphone Jack Replacement
Wat je nodig hebt
  1. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: stap 2, afbeelding 1 van 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: stap 3, afbeelding 1 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: stap 3, afbeelding 2 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: stap 3, afbeelding 3 van 3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: stap 4, afbeelding 1 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: stap 4, afbeelding 2 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: stap 4, afbeelding 3 van 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Headphone Jack Replacement, Locating Headphone Jack: stap 5, afbeelding 1 van 1
    • Locate Headphone Jack attached to Midframe.
  6. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: stap 6, afbeelding 1 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: stap 6, afbeelding 2 van 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: stap 6, afbeelding 3 van 3
    • Use Tweezers to gently remove Headphone Jack from the Midframe.
    • The Headphone Jack is attached with adhesive, remove carefully.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eddie Krause
260 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-6, Leahy Fall 2014 Lid van USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 313
