Inleiding
The antenna is a vital piece of hardware in the i880. It is used to send and receive data submitted between this phone and other devices.
  1. Remove back cover of the phone by disengaging the clip and lifting up on the cover.
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
  2. Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
    • Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
    • Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
  5. Slide and secure new antenna into position. Make sure metal receiver is facing forward.
    • Slide and secure new antenna into position. Make sure metal receiver is facing forward.
  6. Reattach back cover and secure all components in place.
    • Reattach back cover and secure all components in place.
Conclusie
Ryan
13 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G7
3 Leden
4 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 2
Altijd: 67
