Ga door naar hoofdinhoud
Motorola Moto Z2 Force Speaker Replacement
Wat je nodig hebt
  1. Motorola Moto Z2 Force Speaker Replacement, Screen Assembly: stap 1, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement, Screen Assembly: stap 1, afbeelding 2 van 2
    • When separating the sides of the screen assembly from the device's frame, you will need to release five metal clips securing it in place.
    • Three of these clips are located on the left side of the device, and two are located on the right side.
    • You will need to work around these clips with your opening pick in order to fully release them.
    • You can either carefully slide an opening pick around these clips, or leave a pick on one side of the clip while prying the other side with another pick.
  2. Motorola Moto Z2 Force Speaker Replacement, Release the Screen Assembly: stap 2, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement, Release the Screen Assembly: stap 2, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement, Release the Screen Assembly: stap 2, afbeelding 3 van 3
    • Insert a Jimmy or other metal tool between the right side of the plastic display and the metal frame, near the phone's side buttons.
    • This may require a considerable amount of force. Push the tool as far down into the gap as you can, taking care to not scratch the chassis of your device in the process.
    • Tilt the Jimmy downward while continuing to push it deeper into the gap to pry up the right side of the screen assembly.
    • Since the display on top of the screen assembly is flexible and only attached with a slight amount of adhesive, you may end up prying up only the display instead of lifting the entire assembly. If this occurs, remove the tool and try again, this time using more downward force to get underneath the entire assembly.
    • Ensure your tool is behind the entire screen assembly and not just the display. If done correctly, you should notice the thin silver metal midframe come up with the plastic display (as pictured).
    No — *slaps wrist* No. Bad steps! Don’t use the suction cup at all, ever. It causes the two layers to separate immediately, long before the frame clips give way to let the screen come off.
    I’m being super ultra very careful with this second attempt on a new device (that was in pretty pristine condition, if I can keep it that way!), and right when I tried pulling as instructed, the screen layers started to pull apart. Use a blade shoved into the edge of the phone and pry it apart, releasing the latches in the process!
    Matt Falcon - Antwoord
    I have to agree with Matt above. At the smallest bit of pressure on the suction cup, the screen de-laminated from the metal base. It still “works”, but….
    None of the tools in the kit is terribly suited for getting in there and prying that clip apart without splitting the screen.
    Phillip Mills - Antwoord
    lease Read the Comments poste on “STEP 2”, When you apply the heat, the screen becomes unglued from the metal fram that it is attached to. I ended up damaging my screen. You need to make sure that what is coming unglued is the metal, and not just the plastic screen. I found out when I saw another video, where they do not apply heat, they just use a tool to pry the frame-display assembly… But apparently it was too late… You should be more specific about the warning…
    Juan Carlos - Antwoord
    A jimmy does not come with the kit. Buy one before beginning this procedure. It is the best way to lift the screen assembly without damaging the assembly.
    Linsey Linton - Antwoord
    This whole guide has been rewritten since my last comment, and I super appreciate it. The steps are now much more appropriate and less likely to cause damage. Jamming your Jimmy (huehue) into the edge of the screen is actually quite a good idea, not likely to hit anything as there’s nothing but body underneath it.
  3. Motorola Moto Z2 Force Speaker Replacement: stap 3, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement: stap 3, afbeelding 2 van 2
    • With the Jimmy still inserted, insert an opening pick under the silver midframe, on top of the Jimmy in the same location
    • Remove the Jimmy.
  4. Motorola Moto Z2 Force Speaker Replacement: stap 4, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 4, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 4, afbeelding 3 van 3
    • Slide your opening pick all along the right side of the device to release the clips and adhesive securing the screen assembly.
    • As you separate the lower part of the right edge, you should encounter the two metal clips mentioned previously. If you do not see or feel these clips, you are only separating the top half of the assembly! If so, press the screen back down into place and start again from the beginning of the screen removal process.
    this is really for the digitizer and screen replacement. there are still more steps for just the screen.
    James McKinney - Antwoord
    There is an enormous amount of adhesive sticking this thing together. As the adhesive is not essential (it holds together with clips, mostly), you really need to focus on *removing* the adhesive, so that it doesn’t stretch and bunch-up, preventing clean reassembly. Leave behind the adhesive that you can prevent from bunching-up (by cleanly breaking it, in turn by holding down one edge to the phone or screen), so you have some sticky left, but just make sure it’s not bunched-up.
    Revisiting this comment a year later: there’s now replacement adhesive available (or maybe there always was - wish I knew!) for this model in the iFixit store. So, it would be best to remove the adhesive whereever you see it, cleaning everything up and preparing for the new adhesive. That darn adhesive in step 9 below, though… ugh. Work slow, don’t expect it to all be apart by this point.
  5. Motorola Moto Z2 Force Speaker Replacement: stap 5, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 5, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 5, afbeelding 3 van 3
    • Once the screen assembly's right edge is separated, slide your pick around the bottom right corner of the device so it is underneath the bottom edge of the assembly.
    • Slide the tool all along the bottom edge of the phone to slice through the adhesive securing the screen assembly and release the plastic clips.
    • These plastic clips should snap free much easier than the metal ones you released earlier.
    • Leave your tool underneath the bottom edge of the screen assembly to prevent it from re-adhering to the frame. Continue to the next step with a new tool.
  6. Motorola Moto Z2 Force Speaker Replacement: stap 6, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement: stap 6, afbeelding 2 van 2
    • When separating the left side of the screen assembly, take care to not snag the display cable located on the left edge near the bottom of the display.
  7. Motorola Moto Z2 Force Speaker Replacement: stap 7, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 7, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 7, afbeelding 3 van 3
    • Insert another opening pick underneath the bottom edge of the screen assembly and slide it around the bottom left corner of the device so it is underneath the assembly's left edge.
    • Slide your tool all along the left edge of the phone to separate the metal clips and adhesive securing the screen assembly.
    • Like before, ensure you are separating the entire assembly by identifying the three metal clips on the right edge of the device.
  8. Motorola Moto Z2 Force Speaker Replacement: stap 8, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 8, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 8, afbeelding 3 van 3
    • Slide your tool around the top edge of the screen assembly and slice all along it to slice through its adhesive.
    • Take care to not insert your tool more than ~4 mm past the edge of the display to prevent damaging the front facing sensor array.
  9. Motorola Moto Z2 Force Speaker Replacement: stap 9, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement: stap 9, afbeelding 2 van 2
    • There are two large pads of adhesive securing the screen assembly near the top edge but further past the 4 mm that have already been sliced through.
    • The front facing sensor array and cable surround the right patch of adhesive from the top and right, so prying or slicing from the top or right edge may damage the cable. The following steps will describe how to separate the adhesive from the left edge.
    This is a tricky part. See the biggest red-squared section in the photo above? That part always wants to detach — the adhesive to the screen is stronger than the molding that holds the metal into the plastic. The metal will detach from the plastic pretty easily, and there’s no way to get that metal back into the plastic frame (as it seems to have been molded as a single part). So, the adhesive is a booby-trap.
    To defuse the booby-trap, heat the heck out of it, insert one end of tweezers (or perhaps a spudger) from the right side, hold the metal plate down, and verrry slooowwly convince the adhesive to separate. At some point, it’ll start cascading and snap free.
    The metal finger area, between the two red squared sections above, also is a problem area — it’s latched into a frame above the battery, and those latches can get pulled up on top of the frame, preventing the phone from reassembling clean and flat. Make sure to re-insert those tabs so that little edge with the metal fingers sits flat and proper.
  10. Motorola Moto Z2 Force Speaker Replacement: stap 10, afbeelding 1 van 1
    • Apply a small amount of high concentration (>90%) isopropyl alcohol underneath the screen assembly's left edge, near the top of the device.
    • Allow the device to sit upright on its right edge for ~5 minutes to allow the alcohol to penetrate and weaken the adhesive.
  11. Motorola Moto Z2 Force Speaker Replacement: stap 11, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 11, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 11, afbeelding 3 van 3
    • Insert an opening pick as deep as possible under the top left corner of the screen assembly to slice through the left patch of adhesive.
    I found that a plastic card inserted from the left side, and worked with a sawing motion, between the screen and the adhesive worked great after the adhesive was softened by the alcohol.
  12. Motorola Moto Z2 Force Speaker Replacement, Pry Up the Screen Assembly: stap 12, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement, Pry Up the Screen Assembly: stap 12, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement, Pry Up the Screen Assembly: stap 12, afbeelding 3 van 3
    • Slowly and carefully slide the flat end of a spudger under the left edge of the screen assembly. Gradually insert it deeper to pry up the top edge of the assembly and release the right patch of adhesive.
    • Add more isopropyl alcohol as needed, but take care to not use too much, as this may dissolve other adhesives in the device that would preferably remain sticky. Give any additional alcohol some time to penetrate the adhesive before continuing.
    • Only pry up the assembly enough to slide the spudger underneath and release the adhesive. The assembly is still attached via the display cable, and prying the left side too far upward may damage it.
    Again, pay careful attention to the strong block of adhesive sticking the display to a metal shield that’s molded into the plastic frame - the adhesive strength is quite likely to pull out the metal shield from the plastic frame and there’s no going back from that. Not as catastrophic as ripping a ribbon cable, but still pretty bad. See my comment a couple photos up about that.
    I added some alcohol directly to the adhesive patches on this side of the phone and waited a couple of minutes before continuing with this step.
  13. Motorola Moto Z2 Force Speaker Replacement, Open the Screen Assembly: stap 13, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement, Open the Screen Assembly: stap 13, afbeelding 2 van 2
    • Lift the screen assembly from the right edge and swing it open. It is still attached to the phone chassis at the lower left edge, so do not fully remove it yet.
    • If the screen assembly remains stuck, slice the adhesive repeatedly as needed.
    Do this only after slicing all the little ribbons of adhesive that hang around - and clean up any gummed-up, bunched-up strands of adhesive after removing it. I worked at detaching adhesive until the screen was totally free, only held by the ribbon cable, before moving on from this step.
  14. Motorola Moto Z2 Force Speaker Replacement, Disconnect the Display Cable: stap 14, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement, Disconnect the Display Cable: stap 14, afbeelding 2 van 2
    • Use a pair of tweezers to remove the black piece of tape covering the battery connector.
    • Try your best to keep this piece of tape intact and retain it for reassembly.
    Upon disassembly I found no tape on my display cable
    stuff94 - Antwoord
  15. Motorola Moto Z2 Force Speaker Replacement: stap 15, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 15, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger to pry up the locking tab on the display cable's ZIF connector.
    • Use a pair of tweezers to slide the display ribbon cable out of the connector.
  16. Motorola Moto Z2 Force Speaker Replacement, Remove the Screen Assembly: stap 16, afbeelding 1 van 1
    • Remove the screen assembly.
    • When putting your device back together, be sure to reconnect the display, turn the device on, and test all functionality before closing your device and sealing it back up.
    • During reassembly, pause here and replace the adhesive around the edges of the display if you are reusing your screen assembly.
    • After closing your device back up, stack something heavy, like a textbook or two, on top of the device for 30-60 minutes. This ensures a strong adhesive bond.
    When reconnecting the display ribbon I found it much easier if you straighten out major 45/90 degree bend that is in the middle of the ribbon until the entire ribbon is all unbent and in parallel with the display face. You will then have a straight shot into the connector without having to hold the display at a 90 degree angle to the chassis and then having to look around, over or through the display to (and if luck is with you) find, lineup and insert the ribbon into the connector. You have to do a little in 3 dimensional thinking to re-bend the ribbon and line the display back up with the chassis but if you’ve made it that far then you should have no problems. Don’t bend the ribbon back and forth too many times.
    Steven E - Antwoord
  17. Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Tape: stap 17, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Tape: stap 17, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Tape: stap 17, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $6.99
    Koop
    • Use a pair of tweezers to remove the two black pieces of tape securing the battery.
    • Take care to keep these tape pieces intact so they can be reused.
    • While not crucial, this tape helps dissipate heat from the battery. They won't stick back down by themselves, but if the tape pieces are still mostly intact, re-attach them with some adhesive during reassembly.
  18. Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Connector Bracket: stap 18, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Connector Bracket: stap 18, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement, Remove the Battery Connector Bracket: stap 18, afbeelding 3 van 3
    • Use an opening pick to pry up the small black bracket covering the battery connector. It is secured with a small bit of adhesive.
    • Use a pair of tweezers or your fingers to remove the bracket.
  19. Motorola Moto Z2 Force Speaker Replacement, Disconnect the Battery Connector: stap 19, afbeelding 1 van 2 Motorola Moto Z2 Force Speaker Replacement, Disconnect the Battery Connector: stap 19, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the battery connector.
  20. Motorola Moto Z2 Force Speaker Replacement, Speaker: stap 20, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement, Speaker: stap 20, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement, Speaker: stap 20, afbeelding 3 van 3
    • Unscrew the three 1.7mm T4 screws from the speaker.
    There are actually 3 screws in the speaker
    Richard Moffat - Antwoord
    There are indeed 3 screws in mine as well. I updated this step.
    There are three screws, one additional is in the lower right corner (orientation like seen in picture)
    mesotes - Antwoord
    My Z2 Force has 3 T3 sized screws. So be aware that there is often some variance in cell phone construction.
    Krash - Antwoord
  21. Motorola Moto Z2 Force Speaker Replacement: stap 21, afbeelding 1 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 21, afbeelding 2 van 3 Motorola Moto Z2 Force Speaker Replacement: stap 21, afbeelding 3 van 3
    • Use the nylon spudger to lift and remove the speaker from the phone chassis.
    It’s not mentioned in the guide but you need to make sure to gently pry the ambient light sensor off of the speaker before removing the speaker or you will likely end up ripping its cable and connector from the motherboard.
    If this happens the phone will still boot and work but the screen will be stuck at full brightness and won’t shut off automatically when making phone calls.
    Frederick Hallock - Antwoord
    Mr Hallock is definitely correct! Definitely something that should have at least noted, if not given a full description of how to do that! Be careful!!
    Krash - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Davis Reschenberg
321 Reputatie
2 handleidingen geschreven
Cal Poly, Team S2-G1, Livingston Winter 2018 Lid van Cal Poly, Team S2-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G1
4 Leden
26 handleidingen geschreven
2 opmerkingen
step 6 —- 3 T4 screws (not two)
Oleksandr Panchenko - Antwoord
Where to buy replacement speaker?
danwat1234 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 4,924
