Ga door naar hoofdinhoud
Motorola Moto X 2nd Generation Rear Camera Replacement
Wat je nodig hebt
  1. Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: stap 1, afbeelding 2 van 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: stap 1, afbeelding 3 van 3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 2, afbeelding 1 van 2 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Push the eject pin to open a gap and place a guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 3, afbeelding 1 van 2 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Slide the guitar pick to cut the adhesive sticker and peel off the back cover.
  4. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 4, afbeelding 1 van 2 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove two pieces rubber cover which protecting the flex connectors.
  5. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 5, afbeelding 1 van 2 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Release the power button connecting flex connector and battery connector carefully.
  6. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 6, afbeelding 1 van 2 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Twist off all 18 black torx screws and separate the middle housing from front assembly.
  7. Motorola Moto X 2nd Generation Rear Camera Replacement: stap 7, afbeelding 1 van 3 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 7, afbeelding 2 van 3 Motorola Moto X 2nd Generation Rear Camera Replacement: stap 7, afbeelding 3 van 3
    • Release rear camera connector and remove it easily.
Conclusie
Sophia
43.861 Reputatie
62 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 998
